Camber shim kit
Got my shim kit but no instructions, I take it the shims fit between the inner wing and the upper control arm bracket, but is it just a case of unbolting the bracket or does the upper arm need to be taken off as well ? Also any idea what thickness shims should I start with to correct moderate inner tyre wear? As they are not stamped I will have to measure the thickness, but wanted to put some in before taking the car for a camber check so I have a rough idea of what to add/remove.
No posts to show
