tightening the alternator belt
How do i do it?
Im under the car and i can see a long bolt which seems to be the one to tighten it up. Is that right? or is there some more bolts i have to loosen off and then tighten up again.
Thanx
There is something you have to loosen but it's hard to explain. The manual should show you
The part that the long bolt passes through has a nut on the back which clamps it to the bracket. Loosen this off before adjusting (12mm) - also undo the big bolt at the top (17mm) slightly to allow the alernator to move :) Once adjusted tighten both back up :)
Duffman to the rescue again, andy do you just have a photographic memory of the zeds engine?
Could probably talk you through removing and stripping one without even looking at it bud :D ;)
When removing the engine, how the fook do u undo the 6 bolts from the turbos to the exhaust pipes, ive tried everything, blowtorch, extension bars and jumping up and down like a madman, or do i just angle grind them off and get new.
lol
If you try hard enough they just shear off - you don't usually even have to try that hard LOL. Tried something like plusgas?
lol
I,ve just took mine off bud , had to get them glowing red hot before they,d come undone :smash: :smash:
