In memory of Mandy
decat query
When I decat my car, what do I do with the cat overheat sensors??? is it best to cut them off or just tuck them out of the way??
Scotty.
Cable tie them up out the way, i'm pretty sure if you cut them off the light stays on.
Baz
sorry to hyjack your thread but does anyone know how easy it should be to separate the cat from the front section? Its just held on by a jublee clip type thing but wont budge! I need to take at least one exhaust down to get at my prop and wanted to take it down with the cat on. I undid the jublee clip thing that holds the cat on the front and tried to pull the whole rear out of the front section - well its stronger than me! Im gonna have to undo the flange that bolts the cat onto the back section to get it off. Im just asking this as the cat is going to have to come off as well to get at the prop etc.
The cat is part of the front pipe, the jubilee clip just holds a protective cover.
You'll probably need to split it from the downpipes.
Baz
lol that'll be why then. Im a tool.
Ill put the heat sheild back on and take both exhausts down from the front pipes
