Fitting front adjustable upper links
Anyony know if there is a right and wrong way around to fit them ? They appear to be 'handed' and one end is around 1.5mm wider than the other between the bearings, not much but I'm just not sure. BTW, they are Skyline BRN32 and Z32 compatible.
CheerZ
Paul.
If you do a search, this very question was asked only last week and an instruction link was posted. JFYI though whilst the r32 and z32 are reasonably compataible, they are different offsets from the perch. You'll find more details of this in my traders section and pictures!
smithy
http://www.twinturbo.net/ttnettech/aarms/aarms.html
The second picture has four nuts highlighted, these are single use so chances are when you remove them you will need new nuts, not cheap either, approx £3 each and I've had to order mine through MJP Auto and they take up to three weeks from Japan!
Hellraiser and Joely P helped replace mine so they may be able to offer more advice.
Single use? Who they kiddin????? Whack some thread lock on the ****ers job done ;) They're only single use due to the way they lock on the bolt - thread lock does the same job - just make sure you get some tough stuff :)
