Hesitation gone when TPS is disconnected
Could this mean that the TPS is causing the hesitation when pulling off from standstill.
I pulled it out and although it idled rougher, the revs were up and not the slightest hesitstion?
Any help thanks
Doubtful. Have you checked the TPS to make sure it is set correctly. Is the hesitation only when accelertating hard from idle?
I'm guessing you have a boost leak.
Hi there
In reponse to your post on my thread,
hesitates when pulling off ie even just tapping the throttle, there is second delay before picks up. only happens when car is warmed up. When warm ,the revs aldo drop quite low, around 500rpm.
also generally car idles a bit rough.
any ideas or help, thanks
