hesitates only when warm???
Any ideas guys.
When the car is cold, it revs just right and pulls off nicely.
When warmed up , the revs drop and idles weirdly and car hesitates for a sec at pull off??
Please help
mine does this to earlobis. i think it may be a breathing problem.
mine does it the oposite way round, does it when cld, then warm therevs rise to 2000rpm and still runs poor without much torque at low revs
Any ideas guys.
Please help
Mine used to do this , check the terminals in the Yellow plug for the temp sender unit on the top alloy water pipe , probably needs cleaning or a new sender unit ,HTH
What am I checking the terminals for?? thanks
any corrosion (usually green gunk) scrape it off then spray a little electrical cleaner on them
dirtiness :D give them a clean joe, if the wireing is past best and the connector, replace with new one.
sorry i didny reply to your PM last night proper tired bud, do a forum search see what comes up, TBH as i said without having a look its hard to diagnose.could be a boost leak to a bad electrical connection.
You trying to get a free holiday to SA Greg? :rofl:
One thing I did notice is that when the car hesitates for a sec on pull off, the boost gauge drops down past zero and then corrects itself as the car pulls off. Could this indicate boost problems??
Any ideas guys.
When the car its cold, its just right and pulls off nicely.
When warmed up , the revs drop and idles weirdly and hesitates for a sec at pull off??
Please help
Thats just rude, you sure you got the right web forum ????
