Removing HICAS, question about PAS pot
When my car goes in for the rebuild, all the pipework for the HICAS will be removed, as I have a HICAS Elimantor bar fitted. Once this is done, will I need A NA PAS pot, or will I still need a TT PAS pot. Just planning ahead for chromed parts :)
Many thanks
Barry
Best taking richards pot and chroming it mate, once you remove the lines you actually do away with one your existing PAS pot feeds so would have meant capping or cutting off.
smithy
if you follow the hose lines, there is a route from the pump to the tank, via the hicas solenoid. you can chop those and reconnect them.
actually that really badly worded - ill look up john dixons version - he's a lot better at it than me!
