code 13 on ecu please help
hi guys just done a ecu diagnostic check which says its 13 engine coolant temp sensor could anyone tell me where this is? is it yellow plug near rad and also how to fix cheers
yes it is check the connectors and clean if that doesnt work youll have to replace. what symptons are you having with the zed
its in safety mode i think as will only boost to 6 on guage also erratic idle probs 100/ 1800 rpm sometimes the maddive yellow plug on rad has got a bit broken so is a bit loose will this cause the car to run in safety mode?
i had code 13 but the zed wouldnt rev out past 4000 revs when i floored it, thats why i asked its weired we are getting differant symptons wait till one of the tech heads come along
yes, right temp sender plug, clean it up and reset the ecu.
If is still the same change the sender
