If they did NA ones with a speedo that went up to 120 or whatever mine does then I'd have em.
They did an NA set when I bought mine. If you look carefully, some of the clocks dont have the built in boost gauge.
My OEM dials went up to 180mph but I found that the 160mph clocks are spot on. The speedo is spot on, checked against GPS and Conzult. I think the 180 clocks read slightly faster. But whatever happened, my speedo is spot on without adjusting anything!
Do ypu think I can say 'spot on' a few more times, LOL! :x:
i bought a set of these for my jdm tt but as the 160mph scale is where my clocks indicate 180mph i thought the speedo would probaly be out.has anyone used these on a tt without a problem.
Easy to convert speedo, 1 resistor to change
But are those in the group buy worth Double the price of these?
Well as the last Group-Buy were double the price of the current one, I'd say the ones you've been looking at may be poor quality, I don't know.
I've used EL sheeting before, and it isn't cheap stuff, and not easy to work with.
That's all I can say really.
Pretty good quality tbh, fitted well & look bloody brilliant at night. Even better as they only cost me £17 LMAO
