cruise control fooked
as above!
just given up, doesn't work anymore. :headvswal
is there a simple explination or will it cost me a bit of coin?!
nick
Does your horn still work? If not it could be the relay.
explain doesnt work.
Please give more detail
Have you checked the fuse?
Does the Cruise control light come on when you press the button and the and the steering buttons now work.?
If that is the case. Try driving a long, and lift up your brake pedal with your foot and see if it activates then?
the light on the display works but when i try and set the speed...nothing!
the acceleration button doesnt do anything or the set or cancel.
is the fuse just with all the other fuses?!
will check that and the brake pedal later
cheers!
Auto or manual? If its manual its usually the clutch switch needs adjusting...
Could be the brake switch then. Could also be a dry joint in the control unit. There's a large resistor in there which is prone to this IIRC
Andy
Could you explain for me where the clutch switch is on a manual? is it down by the pedals?
Kev
The clutch switch is above the top end of the pedal Kev. As you push the pedal it moves away from the switch. Absolute nightmare to get to and adjust. I ended up removing the clocks and going in from above in the end...
