Hiya, i'm new around here and joined for information and also advice into how i should go about dealing with my Z. I bought this Z a few months back with a relatively unknown history, the only real info i had was that the engine was rebuilt in the last 5 years or so, has atleast a few minor mods (radiator, BOV, potentially turbo stuff?) and that the car ran decently well. i've come to self diagnose that my knock sensor is knackered, my speed sensor either has a bad ground, worn out or needs a solder fix in the dash(0-5mph wiggle upon being stationary occasionally), and due to the 5~ years since an engine rebuild i think the timing belt + tensioners require doing just for peace of mind (the cars only done 4k miles since the rebuild) i'm more electrically inclined than mechanically inclined so i wanted to ask for any reccomendations for shops that are familliar with z's to fix my knock sensor and change the belt + tensioners and to perhaps have a quick look over the general state of parts on the car. The only place i know of is PowerZed but its quite a trek (which i guess isn't the end of the world if y'all reccomend that as the place to go).
Z32 Enjoyer · 3 hours ago 3 hr
i have just bought a new pipe for the drivers side throttle bodie as mine had a split in the top
prob is now that my car will only boost to 6psi on the boost guage instead of 7+ any suggestions? also has irratic idle sometimes runs between 1000rpm and 1200 sometimes even 1500??????
