a couple of quick questions
can anyone tell me:
1 , what the diameter of the rubber pipes that connect the ally water pipes to the block at the front of the engine are ?
( just changed the water pump and now one of these is leaking ) :headvswal
2 , what the grease is that comes with the uprated antiroll bar ?
( lost the sachet of grease and tried to use copper grease but squeaks over every bump )
many thanks in advance
malc
Can't think of size off-hand bud,but the grease your after is Silicone grease. ;) White and very sticky!! :eek:
I have read the sizes before but cant find it for s**t. 26 or 28mm rings a bell. Spose I could go out and measure but im a lazy fooker.
Got some silicone grease if you want.
nice one mate. i'll have to pop down and see you soon
The water pipes that go into the block (thermstat) are 38mm
excellent just wanted to order new pipe before i pulled it apart again
