lights...
you know the little fog lights (on jap specs) is there any other way of changing them when is blown... the screws on the plastic bit on mine are worn and they just go round n round..... and i dont wanna smash them up :cry:
is there anyway of doing it from the inside? :headvswal :headvswal
I think they adjust the beam, to remove the unit you will need to get access to 3 10mm nuts by removing the indicator units.
You need to remove the indicator, then the 3 10mm nuts on the back the light will then come out and you need to remove the 3-4 screws, the back will then pull away from the front and allow you to change the H3 bulb and also the jap spec sidelight bulbs (capless bulbs)
thanks xx
