TC & Timers
Anyone else had a prob with their turbo timer after installing Traction Control?
Timer was set to auto and varied its run time based on rpm (tapped into ecu wire)
All worked fine.
Installed Racelogic (tapped into same wire - I actually tapped into the timer wire about half an inch up where that tapped into ecu wire), and TC works fine.
However - now my timer wont work on auto - seems that TC is stealing the signal.
It shouldnt make any difference that I tapped into the timer rpm wire as its only half inch away from original wiring), and the fact that tc is working show the signal is coming up that wire.
No posts to show
