Electrical problems
:confused: After running the Zed for nearly two years without any problems at all. I was shocked the other night to find after starting the car, then turning the headlights on. After about ten seconds the dipped beam, side lights, rear lights, interior lights all went out whilst the main bean immediately turned on. After that I could not get anything to work bar the main beem. I couldn't even turn the main beam off with the stork. After eventually finding the right fuse down in the drivers side foot well, only to find it blown. Changed it & all was fine. The next few days were ok untill last night after driving about a mile down the road it happened again. All lights out but main beam full on. Has any body had similar problems or got any suggestions how to cure it.
I had the same problem a while back, It was caused by the glove box light switch, caused by the live wire shorting out on the catch when the glovebox was closed.
i had it from the number plate wiring and I have had a few customers with the stereo wiring doing it.
