resistor in det. sensor
- Tap Permissions โ Notifications.
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
- Open Settings App โ Notifications.
Safari (macOS)
- Go to Safari โ Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Go to Settings โ Site permissions.
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi everyone,
Iv'e only had my Z a week or so and am trying to get it running properly..
At the moment it is running in safety boost,i know this as i connected a voltmeter to the wastegate solenoids and the ecu cuts the supply to them on full throttle leaving me with 5-6 psi..
I checked the water temp sensor circuit and replaced the sensor so thats ok..
When i came to look at the det. sensor i noticed i didn't even have one and the wiring harness connector had a resistor wedged in there instead..
I understand that this was probably done to override the sensor..
I tested the resistance of the resistor and it was about half a megohm or 500,000 ohms..
I then did a live volt check from the det.sensor circuit to the ecu and it was 1.95 volts and the manual says it should be about 2.5 volts..
Does anyone know if that is the correct resistor rating and if 1.95 volts i'm getting at the moment is ok..I just want to get it running ok before i replace det. sensor properly..
p.s funny thing is the guy i bought it off has a receipt from S.E nissan for a new det sensor fitted 3 years ago???
