different thermostat?
going to fit a Koyo rad soon
was thinking is it worth getting a better thermostat?
was thinking about sumthing like a cooler running one (had one on my old 2.0 engine)
is there any such thing for the zed? better just getting a new thermostat?
thanks alot
Mark
I think there are 2 diffrent temp opening stats avalible nismo rings a bell.Its quite a big job fitting as its behind cam belt i wouldnt bother but its up to you maybe put one in next time the timing belt is changed.
I think your talking about the earlier opening stat (nismo) to run cooler, if your fitting 'koyo' rad i wouldn't as they run much cooler anyway.
Ofcourse if you have an after market gauge just keep an eye on it and go from there.
Running 80-90c i think is best, so nismo stat may hold you under.
