Speedo/Power steering wonky..
Hi guys, have a problem with my speedo/power steering, which i think is(fairly) common..
About hlaf the time whilst driving, or from start, the speedo stays at 0 or wanders up and down, finally staying at zero. After about a minute, the power steering goes "strange" ie VERY light or VERY heavy. Normally heavy. From reading other posts, it looks like the speed sensor in the gearbox(?). Is there anyone locally(witley, nr guildford) that can fit a new one or diagnose the problem more thoroughly?
Cheers,
Tony
those are the exact symptoms that my mates one had the other day, that was down to a broken speedo convertor, but being a UK you won't have one of these, so I guess it must be speed sensor.
Yah. I've seen that on the boards, but as you say, mines a uk...
most likely speed sensor mate
i.ve been having the same prob, mines a jap non turbo, I put some uk clocks (full unit) in replacing both speedo and converter. The speedo works perfect now and the trip mileage reads correct, HOWEVER the power steering still behaves the same, any ideas! ??? IM GETTING FED UP WITH THE FECKIN THING NOW!
