HELP!!! Urgent Car Sparaying advice needed!!
- Replies 61
- Views 2.8k
- Created
- Last Reply
JonLowndes101 13 posts
mantav8 7 posts
markzx 4 posts
nismo-si 4 posts
Ok as you guys know my best mate and myself have been fabricating vents and spraying my bonnett and the end result was looking gorgeous, but I came to my Z the following day and overnight the paint has lost it's glass look and has gone all speckely, textured and feels very rough too touch in fact if you touch it, it leaves your fingure mark embedded in the laquer as i found out when i put my hand on the bonnett earlier... :slap:
We don't quiet understand what went wrong because it's all happened over night in the cool night air... Should we have left in the Z in a dry garage over night??? :confused:
Ok we've obviosuly gotta do it again this week and understand I now gotta sand it all down with 1200 grit but need to know and help in the times needed between spraying the car and applying the laquer afterwards...
Originally we sprayed the car in 2 pac paint and then put the laquer on pretty much straight afterwards but think he only put a thin coating of laquer on... I can't remember which type of laquer we used I understand you can get 2pac laquer now as well.
Would this have caused the orange peel effect because the laquer sprayed wasn't thick enough or we used the wrong type of laquer with 2 pac paint or should we have left the paint to dry for a certain time before applying the laquer afterwards... It's really weird as the car was fine driving home and the laquer was touch dry, it all happend overnight in the outside air...
Please help, ideally we would like to know:
1: How long we should leave the paint to set before applying the laquer coat afterwards.
2: How many coats of laquer we should apply after spraying the red paint.
3: Standing times between the finished end result with paint and laquer before I can use the Z again.
Thank you most gratefully to anyone who can help as I'm feeling really down and gutted at the moment because it was looking great and now it's all turned to shit...
Here are the pics...
Close up of the orange peeled textured laquer...
The overall specled effect...
