turbocharging an n/a
anybody know how much it would cost to turbocharge my n/a. i did a search but couldn't find anything. would it be a good idea? is there someone on here who could do it? all comments are be much appreciated.
cheers
alex.
  • Replies 30
  • Views 1.3k
I am confused by Alex and Shunter having the same picture.
damn didn't notice that!! :slap: i'll have to look for an origional pic now!!
from what I just found out by accident, the propshaft and final drive are different on the TT too. I am attempting a manual conversion on my N/A but now need a prop because of it.
  • 8 months later...
you could just change the prop uj and use the front half or grind the inside out slightly on the NA box in which case you can use the same propshaft from the NA and use a TT clutch and flywheel you may also need to space the starter out slightly aswell
differential/final drive is differant although ratio is shorter so better acceleration, some top end and strength is less, but should be ok running reasonable power
Ive yet to find out what it feel's like?? :confused: I did my diff conversion using my tt front part of my driveshaft and an n/a rear prop on my auto and the n/a Diff does not really notice much at all :nelson:
