plenum removal
Hi, planning to remove the plenum on my uk tt for polishing et etc...easy enuff to do or is there more to it?
Mark
It's a bit of a pig, especially if it's not been removed before and all the EGR and throttle body heating pipes are in place. Took me nearly 4 hours !
4 hours Andy and you know what ur doing!! ah well, have to do it sometime..also with it removed, I can get to some of the pipework at the back of the engine and replace them as a preventitive measure..anything that must be done?
Thanks to ya both
Mark
Bleurgh why go to TTnet when you have it here:
http://www.300zx.co.uk/forums/showthread.php?t=30838
Worth bypassing the coolant hoses to the TBs while you are at it, also consider removing the egr but this involves quite a lot more (fidly) work...
