Ecu harness wiring
Afternoon all, Iv'e been searching round for the Ecu harness wiring this afternoon so far i have found all the pinouts i need but got 2 different diagrams showing 2 different ground wires.can anyone confirm wheather pinout(E) is the ground or the pinout above it with red arrow pointing to it.
I dont want to connnect switch on n it go pop so any help would be great thanks. :nana2:
The one marked E is the main earth, the one above it seems to be used for sensor earths...
Cheers Duffman op man. :dance: :)
  • 10 months later...
Hi Can anyone tell me what each pinout does. as i want to fit my turbo timer and vsd. thanks Jay
1990-1995 Nissan 300ZX Pin
1 Ignition 1 Coil #1
2 Ignition 2 Coil #2
3 Ignition 3 Coil #3
4 AAC Valve
5 A/T Control Unit PW
6 Cooling Fan Relay (300ZX Turbo Only)
7 Tachometer
8 AIV Solenoid (90-92 300ZX)
9 Air Conditioner Relay
10 ECM Ground
11 Ignition 4 Coil #1
12 Ignition 5 Coil #2
13 Ignition 6 Coil #3
14 A/T Control Unit
15 A/T Control Unit
16 ECM Self-Shutoff Power Source
17 Data Link Connector
18 Fuel Pump Relay
19 Cooling Fan Relay
20 ECM Ground
21 Diagnostics Receive Data
22 Diagnostics Transmit Data Switch
23 Knock Sensor
24
25 Wastegate Solenoids (Turbo Only)
26 Mass Air Flow Sensor Ground
27 Mass Air Flow Sensor MAF
28 Engine Coolant Temperature Sensor
29 Right Side Heated Oxygen Sensor
30 Sensor Ground
31 Diagnostics Clock EGT
32 Malfunction Indicator Lamp
33 FICD Solenoid
34 Power Steering Oil Pressure
35 Fuel Pump Voltage Control (300ZX Turbo Only)
36 Fuel Temperature Sensor
37 --- Spare Temp Input Avail, 0-5 Volt
38 Throttle Position Sensor TPS
39 EGR Temperature Sensor
40
41 Camshaft Position Reference Signal
42 Camshaft Position Signal
43 Start Signal Cranking
44 Neutral Position Switch
45 Ignition Switch +12V
46 Air Conditioner Switch
47 Diagnostics Check Signal EGT
48 Power Source For Sensors +5V
49 Power Supply For ECM
50 ECM Ground
51 Camshaft Position Reference Signal
52 Camshaft Position Signal
53 Vehicle Speed Sensor
54 Idle Position Switch Switch
55 Left Side Heated Oxygen Sensor
56 Throttle Sensor Output Signal
57 Power Source For Idle Position Switch
58 Power Supply Back-Up Permanent +12V
59 Power Supply For ECM
60 ECM Ground
101 Injector 1
102 EGR Control Solenoid Valve Idle
103 Injector 3
104 Fuel Pump Voltage Control
105 Injector 5
106
107 ECM Ground Power Ground
108 ECM Ground Power Ground
109 Power Supply For ECM
110 Injector 2
111 PRVR Control Solenoid Valve Injector
112 Injector 4
113 VTC Solenoid Valves
114 Injector 6
115 O2 Sensor Heater Injector
116 ECM Ground Power Ground
Thanks Kev, thats a massive help, ive worked out what pinouts i need now. My fueling is more or less still the same but it is deffo my efi harness, so i have done a temorary fix until i can get hold of new connectors and splice them in. At the moment im getting 30 miles to £10.
Ive also fitted a new afm and i have a ecu which i am going to socket and chip before fitting in a few weeks. but i realised last night that ive got my mot coming up in around 10 days so need to prepare for that....
