nissan 300zx 1990 import
hi i have a 300zx inport with ajustable coil over shockers fitted the springs seem very strong making the ride very hard can you please tell me where i can get weaker springs many thanks dave
  • Replies 31
  • Views 1.4k
i swap my stock set up with ya :rofl: most ppl want coil overs and stiffer suspension :D
i just want some weaker springs and keep the coil overs please
Coilovers come with maching shocks and springs. Usually you can specifiy the spring rates you want. What make are the coilovers ? I think you will need to order softer spring rate from the manufacturer
hi the coil overs that i have got have just got jap writing on them so i dont know the manufactor
You should be able to ajust the ride height and damper setting so as to get a softer ride by winding the sping collers down. It will raise your ride height, but that will do it.
hi the ajustable collors are a the bottom of the spring so i will lower the ride height i think shorly
How much thread is there under the collors? If there is thread under the collors you wind the collors down towards the wheel hub. This extends your springs and raises the ride height, making the ride softer. Just wind them down 5 full turns at a time and test drive until you get the feel you want.
If the collors have no threads beneath them and you don't know what make they are then your looking at changing the lot.
ok thanks mark i will try that let you know many thanks discodave
have wound platforms down but still very hard ride i think i need some more springs can enyone help
What tyre pressures are you running, if too high that can give you a bumpy ride.
hi can anyone please tell me what the standard coil spring poundage is for front and rear for my 300zx tt with coil overs thanks dd
I compiled some data on this a while back ...........
Nissan OEM
Front
3.0kg/mm (168 lb) US 2S & 4S NA
2.8kg/mm (157 lb) AUS 4S NA
2.8kg/mm (156 lb) US TT
2.6kg/mm (146 lb) EURO 4S TT
Rear
2.2kg/mm (123 lb) US 2S & 4S NA
2.2kg/mm (123 lb) AUS 4S NA
2.4kg/mm (134 lb) US TT
Eibach Pro springs
Progressive Front
(185-250 lb)
Rear
(145-200 lb)
D2 RS Coilovers
Front
13kg/mm (727 lb)
Rear
7kg/mm (392 lb)
Tein Flex Coilovers
Front
8kg/mm
Rear
6kg/mm
G-force Coilovers
Front
13kg/mm (727lb)
Rear
7kg/mm (392lb)
hi hi have g force coilovers fitted i dont know what the spring poundage fitted at the mo but to hard what poundage do you recommend thanks dd
coilover shocks does 5kgs front 4kgs rear sound right please thanks dd
does anyone know what the standerd coil spring poundage for normal road use should be for my 300zx with coilovers on front and rear thanks dave
They are made by Heibache So you could speek to Heibache UK with regard to replcement springs.
Just out of curiousity, What were you driving before the Zed, because a good sports car set up is a bit Teath rattley.
hi the coil over shockers i have are jap spec something like effice written on them i have been driving a wrx inpreza before the ride in that is ok but the springs on the 300zx just dont move at all much to strong springs i think
anybody know the standard spring poundage of my 300zx with coil over shocks please
hi i am trying to find the standard spring poundage for my 300zx coilovers can anyone help
You said earlier they were g-force coilovers ? I posted the g-force coilover spring rates :
G-force Coilovers
Front
13kg/mm (727lb)
Rear
7kg/mm (392lb)
Which is considerably higher than the more popular Tein coilovers.
Its worth noteing that the ride firmness/harshness is not just down the springs, but the strut damping rates. The spring rates are matched to the damping rate adjustablity range.
hi no sorry they are some jap spec ciffe or something
ciffce thats what is says on the shocker mate
the springs are deffenatly to strong
all i would like to know is what poundage springs to put on the front and rear please
standard spring poundage for nissan 300zx is 145lb front and rear can anyone please tell me if this appl to coiloversies
