pas pot
got to change my pas pot any tips or advice on doing this reguarding the fluid etc
your going to loose fluids how ever you go about it,you could syringe some of the fluid out of the pot before you take of the main feed,then its a case of collecting any that drops down,pull lid of remove 3 10mm bolts that hold it to bracket,slacken all jubille clips or clamps,then swap pot over, top up with car running and turn wheel from lock-lock either way,until no more fluid is needed, take for a test drive on retuen check levels, and top up as needed
job done :)
