Autowatch Alarm help
hi
battery is dying on my key fob i have a replacement but how do i programme it to wrok on my car
help
rav
It says in the manual and I qoute
"The remote control battery life is about three years. As an indication that the batteries need replacing, the green LED on the remote will flash when you depress the button instead of illuminating continuously as normal. The remote control uses two lithium CR1220 batteries which are avaliable from your fitment centre and most camera shops. To change the batteries, undo the two philps screws on the back of the remote. Place the remote on a flat surface with the button and LED facing upwards. Gently separate the two halves to expose the batteries. Remove the old batteries and insert the new batteries observing the correct polarity. The polarity is shown on the plastic."
Marv
thank you i`ll get them changed.....but it would be helpful to know how to programme the other fob as the rubber button is starting to break!!!!
Had a look for you mate but said nothing about programming the fobs
Marv
If you have the emergency card with the override number you can order new fobs from autowatch if that helps?
Marv
