best way to drain petrol tank
as above i need to get £25 worth of watered down fuel out me zed :headvswal
I find the best way to drain the petrol tank on my Z is to push my right foot down hard on the right pedal!!! LMAO............. :dance:
Seriously though - there might be a drain plug or if not, I don't think the fuel tanks are anti-syphon so you might be able to drain some off with a hose or tube?
Nigel
Pull the fuel hose off the filter and let the pump do the work! :)
would you not have to keep turning the ignition on and off? also would it not take ages?
no the pump will keep pumping and you will be suprised how fast it will empty the tank.
Woohoo!-got sommat' right! :wack:
thanks guys is it the pipe towards the back of the engine bay or infront of the fuel filter
the pipe at the rear of the filter although it would be best to change the filter also.
i will thanks who on here sells them i need a new oil fliter too
mjp. :)
done it today thanks for the help guys. The pump didnt keep going though when i turned the key i could here the pump but it cut out. Brother had a pump that i connected and got it out that way, zeds going fine now :nana2:
the fuel pump needs a signal mate from the cas unit to work.as soon as the cas reads 1degree it latches the fuel relay.the pump will only go when the engine is cranked.all i do is plug a spare cas into the cars loom and turn the drive by hand.
