Need some advice guys,
Currently have an auto TT, but looking to get it converted to a manual. Have got a RPS TT organic clutch already, but in touch with a guy who is breaking a non-turbo Z32. Can anyone tell me if the non-turbo box will fit directly or will I need additional bits. Remember from previous post that the bell housing might be different.
thanks
ronnie
Hi Ronnie, i'm sure the tech people will be along soon to tell you exactly whats different but it deffo doesnt just fit on and if i remember rightly you couldnt use the TT clutch
Paul
Am only going on what i can vaguely remember myself mate, but yes a small mod required on bellhousing and something out spacing out the starter from the fly ?? search and you'll find it ;)
cheers
smithy
it will fit, but you need to grind the bellhousing a bit.
http://twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=1595122
And put a 2mm spacer on the starter motor housing. If you hadn't allready got the clutch and flywheel you could have just got a NA lightend flywheel and uprated clutch. This would also have helped the feel of the clutch.
My first Manual convertion was NA box
So you'll need a TT manual prop and TT manual Speedo sender.
Mike Feeney does recon Props with new center and UJ bearings. about £200
thanks guys, much appreciated. looks like it will be too much additional cost and problems as already have a TT upgraded clutch. also think that the NA does not have a clutch booster.
ronnie
