Is there anyone I can send a datascan log file to who can understand, interperate and translate for me please ? :bow:
Thanks to Legrath for sorting the registration out for me, cheerZ mate :duffer:
Will send you the file later today clarkey, have emaild you anyway.
A quick question on the datascan
The speed doesn't seem to be reading correctly, I have set the wheels size to stock that I have all round, jspec but the speed still isn't right. Is that because I have stock jspec kph clocks with the mph convertor ?
yes, set the datascan speed to kph, the reading you get is actually mph.
Ahh right, so its a small glitch in the software then
Had a look, everything seems in order, anything im looking for in particular?
Only things to note being TPS is at 0.46v at closed, should be 0.44 but tbh probably makes 0 difference.
o2 sensors - both working and swing properly, however they both keep going right down to 0 and staying there for a little. I've not seen any that do this before, could be normal though.
Water temp increased 5 degrees during your bout of speed, 87 is still a good temp though, nothing to worry about in that area.
