god damn clutch!!!! (urgently need hlp)
geeeeeeeeeezooooooos!!!!!! just my luck!!! supposed to be taking the car to phil at c&s wood tomorow gets in it this mornin and it wont go in gear!!! its been quite difficult recently but i was going to mention this and hopefully get it sorted by phil!!!
anyhow it wont go into gear at all now, so im thinkin clutch fluid, ive checked the res. and it was empty filled it up and bled the two nipples there was a bit of air in the system but now just fluid squirting out of the nipples, so i take that it is bled???????
please can someone help i need to get moving so i can take to phil 2moz. :headvswal :headvswal :headvswal
It's a real PITA to get the clutch system free of air.
if the clutch pedal feels very light, there's air in the system and you will have to keep bleeding until the pedal starts feeling firmer.
lymon the pedal feels really really light theres no resistance at all, am i right- pedal in, undo bleed nipple, tighten bleed nipple, then out with pedal? and repeat process.
if it feels really light and the cylinder was empty when you checked it then it sounds like you have a leak
but yes you are right, that is how to bleed a hydrolic system, good idea to get one of those little pipes with a none return valve
hi m8, zeds are a right bugger to get a pedal unless you know this, you need to get the front of the car up in the air as high as you can without fookin up bodywork and what have ya, now bleed the slave and then bleed the one under the bonnet, took me 3 very stressfull l8 nights at work b4 i rang my dads old pal at nissan, its just one of those little quirks of the car, good luck fella.
:hyper: :hyper: :bow: just got the bite on the pedal was tryin it on me own earlier but me old mans just gimme hand with it and wooolaaa!!! thanks for ya help tho guys really appreciated.
:hyper: :hyper: :hyper: good on ya fella :hyper: :hyper: :hyper:
