Electrics
Ok I definitely need help on this. My Cobra alarm has a red led on the dash and I was hoping to change it to a blue led to match my interior lighting. Now looking through the spec the red led is running on 12v and the blue led I have found runs on 3.6v thus I need to put a resistor to get this to work.
Now the thing is any ideas what strength resistor do I put and where do I get one ? Also, will this resistor be attached to the red wire of the blue led going back to the control unit or the black one or do I need 2 resistors on both the wires ?
Never was an electronics guru so need help guys and gals.
Cheers !
Cheers !
aint got a clue on that one,but you,ve just burst my bubble because i thought you WERE a gizmo head with all that talk of remote controll bonnets you posted that you fitted to your zed
http://www.300zx.co.uk/forums/showthread.php?t=67091
Mate, installing a kit according to instructions given and tweaking it to your needs is one thing. Pissing about with electrics with no wiring diagrams and doing things by trial and error with a possble risk of damage is something else (common sense I thought). Didn't realise you had a bubble to burst. Sorry to short fall your expectations.
know what you mean about instructions all fvcked up :( by the way i was,nt being funny dude just thought you knew about all that resister shite ;)
remote control bonnets and HUSD's gotta be a systems diagram freak lol
There is a specific formula to calculate resistant / currents /voltages when you are trying to piss around in my case here. What this formula is I don't have a fuking clue.
Secondly, the wires going back to the control unit doesnot show up on the wiring diagram.
If I knew the answer bud I wouldn't be posting. However it seems to me I am being mocked for some reason ?
Why is this the case with all due respect ?
hey syed ime not mocking no one just seems strange that somebody with your gizmo knowledge should ask a basic simple resister question thats all.iff i could help you i would and in my case its case closed ;)
I suspect the LED is a bog standard one and there is a probably a resistor somewhere.
Why do you say it runs on 12v? Have you metered it?
i thought the led was a resistor in its own right
yup, agree with mr S, will be the same just swap like for like
you will need one resistor on the red wire.
>> Supply is 12v
>> if the blue LED drops 3.6v you need a resistor to drop the other 8.4v
>> LED's require a current of about 0.02A
>> a 0.02A (20mA) current in the LED will be the same current in the resistor
>> Voltage = Current x Resistance
>> Resistance = Voltage / Current
>> Resistance of resistor needed = 8.4/0.02 = 420 ohms
>> Go for a little higher and make your LED last longer
>> SO : about 450 ohms.
>> if needed: Power = Current x Voltage
>> Wattage of resistor needed = 0.168 watts
However im gonna stop there cos the red led wouldn't be there without a resistor already so im 99% sure you can just swap them over, just put it in the right way round, the legs on the LED should be a different length indicating +'ve and -'ve.
