front crossmember
is it neccasary to drop the front crossmember to remove the engine?
not necessary no.
If you are takeing the engine out through the top then no. But some peeps take the engine out from the bottom ?
you dont have to but it makes it alot easier so well worth it ;)
but dont you have problems lineing it back up again. so far i have removed everything attached to the engine (that i can see) apart from mountings, gearbox and steering coloumn. how many engine mounts is there?
no cos you just undo it so it comes down on the suspension and back up on the suspension again so it lines itself pretty much
Mike
so how much does it drop exactly? do you just drop it leaving the bolts in or fully remove the bolts?
No, but it helps.
But if you are taking it out with the gearbox then yes.
its only 7 bolts which are easy to.
we drop it once we have taken the weight of the engine as if you dont it will drop quite low under the engines weight but it means you can leaver it down to make sure everything clears ok
this may seem a silly question to some people but how does lowering the crossmember help as the engine is coming out through the top
well the engine doesnt just come straight up it has to come forward and up at an angle so the more clearance under the engine the better :)
we have to really pull the crossmember down when doing mine as the external wastegate hangs down past the crossmember lol
all fun and games
