August 11, 200619 yr disconnect negative on battery,remove passenger side floor mat,remove 4 bolt on wooden panel and remove,remove the 3 bolts on the ecu bracket,remove the ecu gently dont stretch the wiring,unscrew the 10mm bolt holding the blue plug in to the ecu,separate the ecu from the bracket(4 screws) then reverse for refitting.i am no mechanic and it only took me around half an hour!! good luck
Is there a write up or pics of how to swap out an ECU please ?
Thanks !
