Hi people,
Bit of a novice question this one but, which aftermarket gauges should be fitted to the car??
I'm looking to get all the important ones on. :)
Cheers guys.
Boost (presuming it a TT)
Water Temp
Oil pressure
are the 3 most important, and the stock gauges can be very innaccurate.
Some also fit :
Oil Temp
Volts
Water Temp
Oil pressure
Some also fit :
Oil Temp
Volts
Thanks Legrath. I've got the boost one on its way, any idea where I can get the rest??
The most important thing is to get good quality Gauges. Such as Defi, Greddy, HKS. among others. Other wise don't bother, becaue most are as inacurate as the stock ones
Water Temp
Oil pressure
Some also fit :
Oil Temp
Volts
Uncanny!!!!!!!!! I've just finished fitting all of these in mine. I've gone for Autoguage guages from http://www.guageplace.co.uk I can't say how accurate they are as I have nothing to compare them to but I can say they work alot better than standard ones.
Cheers guys. If I'm going to do something then might as well do the best. So will look for the quality ones as markzx suggested.
Thanks.
Thanks.
Defi are about the cheepest of the real good quality ones though not as bling and go for electrical or digital instead of mechanical.
Beemon Tweeks do the full Defi range.
