Performance chips
which one do yu use?
and where do you buy it?
thank you
mines already got one in, i shall have a look on the documentation later and if it isntone of Andys try one of his as a comparison..
T
If you look on the link above, andy has compared his to a jwt chip and it seems as though andys chip was better in all tests
I haven't seen mine back to back with John's or his back to back with JWT though.
just wondered as mine is a john dixson
Nothing wrong with a JD chip, knows his mapping stuff does John as I expect Andy does as well.
Can you run a andy P chip on 'safety boost'- 5/6 psi? I would like to run my zed at minimum boost on my Profec IIB in 'off' mode then have the two settings at lo->9psi and one for hi->14psi
Yes, don't see why not. Would be just like running on half throttle all the time ! :D
andy i know you have said that it is possible to set a eprom up for two maps could one map be a safety boost map to activate the wastegate solenoids, and if so how would the maps be made switchable on the same eprom?
I am looking for a map for whenever i have to give my car to garages for work that means they dont have the full power to abuse that i can then switch to the number 2 map that i have from you now.
I do dual switchable maps. The easiest thing for what you want is the 2nd map with low rev and speed limits. eg a 'valet mode'.
