prop replacement
Hi Guys Was Thinking Of Changing My Prop For A One Piece, Either Alloy ,or Carbon, Any Ideas Where To Get One From, And Has Anyone Done It, And Was It Worth The Expence Cheers Guys .ian
do a search on propshaft yani , people have talked it to death, personally I am leaning towards a reworked 2 piece
the only downside with a 1 piece,is if it shatters/snaps and it happend to drop to the floor your car may make a good pole vault,iv heard of it happening :wack:
there is a company in newbury that do 1piece props etc do a search for a company in newbury,not sure of name hence brief explaination :)
i wouldnt go for an alloy prop as its not got the strength so if your going for one then either steel or carbon, personally i went for the steel as its just as strong and yes its a little heavier but not that much heavier and concidering the steel one is about £200 and the carbon on over £1k :)
didnt think a CF one was that much??
i believe James (jaffa) has one :)
Boomin, I might have it off you, what sort of cost?
Hi John,
It's out at Z-Tech right now. I'm going out there on the 11th. Can I tell you then ( at that point I'll give you the low-down on it ).
Not sure exactly what it is.. only that it is custom made and lightweight ( as per the advert when I bought the car )
After the 11th.. I'll come back to this thread and give you the low-down. if you are still interested, I'll get it to you at a deal.
