what injectors do the z32's use?
what cc injectors do the z32's use? and do they fit the ca18det?
375cc if i remember correctly. I think they do fit the CA18 and SR20 but I might be wrong.
its ok they wont be large enough anyway
They will only fit one of the 200sx engines as SR20DET and CA18DET use diffrent injectors side feed and top feed not sure what the VG30DETT use.
They are side feed just found out and alot of the s14 sr20 boys fit subaru sti injectors there are a straight fit you just need the plugs from the subaru .they are yellow injectors and are surpose to flow 480cc but my mate had some cleaned and flow tested at 510cc .these come up on ebay for around £70 with plugs for a set of 4 will need 6 for zed engine . :duffer:
No - they don't fit CAs, and they're the same size so wouldn't be an upgrade.
I used cossie greens on my old Siliva which used the CA18DET Engine... Worked a bloody treat!!! Get your fuel pump upgraded to so you get the flow!!!
Do many people bother upgrading the injectors on zeds? Was talked about all the time on sxoc when i had a 200sx, but doesnt seem to come up much here
Yes, stock injectors are at max flow by about 15/16 psi. Most popular upgrade are Nismo 555's
And the nismo injectors are a straight swap out? (i no fuel rail issues etc...) Not withstanding the need for a new ecu chip
