Air Conditioning
Hi people,
After by-passing my heater matrix (thanks again to pk1 as his pics on the issue helped me alot) as it was busted, I've noticed that my A/C is not working. I just wanted to know if this is due to the matrix not connected or could there be another reason for this. If the matrix has got nothing to do with it, what do you guys suggest I should look at.
Any help would be appreciated guys.
Cheers.
should not have anything to do with the bypassed matrix.
could be a stuck airmix door.
do the ac lines in the enginebay that go into the bulkhead get cold if you switch the AC on ?
First thing is to make sure the compressors actually going. When you switch it on check the front of the compressor is going round.
If it is and no cold air, you may want to get the gas checked.
I will check it out and get back to you guys. Thanks.
A bit of a novice question this one but where can I find the AC lines in the enginebay? When by-passing the matrix I found 2 hoses that went into the bulkhead that lead to the matrix which I pulled out and then by-passed.
