Door locks jammed
Dont usually lock my car with the key but tried to last night and found the drives lock jammed solid and passenger one really stiff, taken a look inside today and everything is still attached as it should be, had a good spray around with WD40, all the nylon joints seem to be fine. Car locks up fine via remote, and if sat in the car it locks from the interior switch, just not from the door lock, any ideas as its hard to see properly inside the doors. Cheers guys and gals :duffer: :duffer:
itl b stuck with not being used, keep piling in the WD40 and rattleing the key in and out and wiggeling
