Turbos
I think one of my turbos is leaking oil therefore want to start saving up for two new ones.....
Is there something i can replace which will be better and quicker than standard or even a little more boost without having to start changing anything else to strengthen any other engine parts.
Costs too would be good thanks........
something like JWT 530's, around $3-3500 IIRC
mark (topless) at zen garage would be near you, prob worth giving him a call, think he was doing a good deal on turbo installs :)
Have you checked its not something else thats at Fault? like pcv valves or valve seals?
Don't think it's pcv's as the slight smoke was coming from the front right just under the drivers door???????
I had smoke from the same place, turned out to be oil leaking from the back of the crankcase/engine area on the right bank, onto the exhaust pipe, which was then causing smoke to come out from under the front right. Might just need some new gaskets?
I doubt its your turbos then! :cool:
