July 16, 200619 yr I recently swap a na for a tt. I was having issue starting the engine (Injectors were clogged) I've fix that I started it this afternoon, engine seems to work fine. but this is my first turbo car and i just want to know if boost is normal... on idle i have 20 psi of vacuum, I can't put the car in gear already so I rev the engine on neutral like 4000 rpm and only get 0 psi on stock turbo is this normal? will i get more boost when a gear is engage?
July 16, 200619 yr you will never get positive boost on idle or no great amount anyway, 20inhg is fine, shows the vacuem side is working well
