det sensor help
It would probably be the wiring from the connector to the ecu then :(
Vijay
try resetting the ECU, i had this problem.
others say it clears it self, but in my experience it never has and u need to short the diag plug to enter diag mode then short again to exit it properly.
check ur installation of your resistor first tho before u go raking in about the ECU terminals
just thought on this one,have you the resistor on the ecu end and not on the sensor end :x:
yea not ad chance to av a go at it again yet did it as link so its ecu end next then i know if its wireing probs if it clears usein data scan
cheers
boys
let u know my outcome :wack:
