how to remove....
how do you remove the wings and bumper. ive removed all the bolts i can see. the wing is loose but seems to be held on by the bumper. do i need to remove the headlights. i cant see how they are held in. help.....
think there are 2 bolts each side where the wing meets the bunper mate..
take it your repairing what the Mrs broke then ?
what happened there? are you back together and is she paying?
yes its getting repaired. no i aint back with her. will i be able to just match the colour for the wings and bonnet or will it need a full respray as i dont want diff colour wings. it has had a full respray at some point not that long ago. also about the windscreen where will i get one and how are they fitted in? any help is much appreciated
Hi,I know that the windscreen is bonded,mine was leaking as well as being cracked so used rac to replace on my insurance as they are expensive and also hard to get hold of unless 2nd hand and yes there is a couple more bolts holding the bumper on, the online manual should help if your`re stuck.Good luck
