Apexi FC Commander
Has anyone fitter one of these in their Zed? I reckon it would be well worthwhile. I've got one in the rx7 (seem to be standard upgrade for rx7 people to sort fueling ,etc). I absolutely swear by it. Its got everything on screen: intake air temp, coolant temp, inj duty, knock sensor, speed, the lot.
IMO its much better than having millions of dials and screens everywhere blocking your view. In particular the a pillar pod which I find annoying. If you consider you spend £130 on a greddy/defi gauge times four (egi temp, boost, air temp, water temp) plus fitting and extra sensors it is just as much as the £500 odd squids for the apexi FC and a setup session.
  • Replies 27
  • Views 1.8k
Yep the stock ECU is very good at its job. Has better resolution fuel and timing maps than most aftermarket ecus too - 16x16 as opposed to 8x8. There's absolutely nothing wrong with the stock ecu - you can even map it real time using the zemulator from http://www.ashspecz.com ;)
PFC's are 20x20
