Me again.
So I have two questions:
RobHowl ·
see three zeds in the space of 10 minutes today
1st was a white/ maybe silver near bromley town center at around 740 pm this evening
2nd was black on the a222 near chislehurst golf course 10 minutes later
3rd was yellow about 15 seconds after the black zed heading in the same direction
