looking for 350-400BHP
Would like to get 400bhp from my ZED it's a UK manual
Been on 300.org went to upgrades and looked at stage charts from stillen and SGP, (this bring's up NEW ZEALAND 300zxOC) it show's 405BHP at 14.5psi is this poss on a UK car? What can i get for £500-£1000?
Any help would be good, phone number's Web site's etc.
  • Replies 29
  • Views 1.7k
Just got home from having a power run about 15% down on std 210bhp at hub. he said it could be a blocked cat, going to comp test over weekend.
Do an ECU diagnostic.
Get your Conzult socket. (Grey block connector found under dash near bonnet pull.) put loop of wire into both side of port 9 and the ECU will start to blink. ( ECU found under Kick plate which is under carpet at front off passenger footwell.) The ECU has a little red led on the bottom end of it and it will blink. count the number of long blinks and then the number of short blinks. Long blinks are 10's ie 5 long blinks = 50 short blinks = units ie five short blinks =5 and the two together = 55 . Then check the ECU blink code on the online manual. If its on saftey boost it would be down on power by about that much. Better to know what really is wrong before you waist money on things that maybe OK.
P.S. this all goes to show that my original statement of make sure everything is OK before you start trying to tune. A standard Zed pushing full power is a lairy beast. So a heathy car my be more than enough for ya mate.
Ok going to get a controler, chip (poss from andy) a good zorst de-cat's and a good filter. 300-320bhp at wheel's i hope
