Fitting a Stereo
hi guys, hopefull you can help.
I have spent all day replacing a main feed hose pipe on the power steering and cant be arsed to do any more to the car today.
but is there anything i should be warned about before i change the car stereo? is it very easy to take out ? or do i have to take the whole dash out (like i had to with my supra)
Guys, any tips before i start would be very helpfull indeed :)
Dash out, not as bad as a supra but similar set up, you`ll need a conversion lead and maybe aerial adaptor, apart from that straight forward.
Bob
thanks for the heads up sir :)
i hope not, the supra was a mare, had to unplug all the dash controls, and remove the whole dash to change :(
I can see 4 screws so far (the covers were missing when i bought her)
2 by the fan grills, and 2 just above the the top bay, is there any more?
also, can you help - the unit i havbe in her has a tape deck *spit* and cd unit (2 units) I will want to take both out, so can i get a blanking plate for one of them??
ideally, if someone, has one, can i see a pic... i want one, and modift it, so i can put my amp gains in there.
to right, dead simple to get out, just take the whole trim pannel out of the middle of the dash disconnect the clock. Then the screws should be visible for the brackets.
You can fit a blanking plate or get a pocket that will fit in, think Nissan do one (can`t remember, not had a Z for a few years) or Autoleads do one, think it`s FP-06-00 but not 100%, can check Mon if no one else knows.
The screws you have taken out are all there is, just a couple of clips on the bottom by the clock and job done!!
Bob
