Uneven Tyre Wear
Had a look at my front tyres today and they are not well ! The inside edge of both front tyres is completely warn down (to the white !!) but the outer edges are OK. Is this caused by tracking or camber please and if camber is there a way to adjust it as standard or do I have to buy something to do it ??
Wheels fitted are 18"s by the way.Need to get new tyres ASAP and don't want them going like these. :(
has the car been lowered?? if so almost defo its camber
get a correction kit and fit that mate
Not to my knowledge M8.
Which was it M8 ?
I've been told that the Camber Arms is the same fitting as the S13, Does anyone know whether that is right plz ??
Which was it M8 ?
i dont know yet Z-tech are doing it now
if your getting uneven tyre wear on the inside the only ajustment that can be made,is by purchasing upper ajustable control arms,once fitted the car needs to have a 4wheel alighnment and setup with spec,in the long run you will get your money back,with the amount of money you will save on replacment tyres
greg
i have the very same problem with my tyres, all four going bald on the inside very quickly. the adjustable camber kit is deffo one way to go, however, is it fair to say that the reason for this camber alteration is due to the extra 'squat' caused by lowering springs?... am i right to assume that if i used a lowering kit with shortened shocks that this movement in camber should cancel itself out?
any1 know of the kyb adjustable suspension shocks that smithy offers are of a standard length or shortened?
Chunk has a set of front camber adjusters for sale at the mo
never seen the point in buying uneven tyres.... :wack:
Have a look at this site.
http://www.wheels-inmotion.co.uk/index.htm
It expalins it all. The guy that runs it is also a member on this site. He sorted my 4 wheel alingment OK. You will need to get adjustable upper arms for the camber though as these aren't adjustable as standard.
check out smithys range of adjustavke suspension products http://www.smithys-place.co.uk
