Camber arms or shocks?
You may have seen my other thread about my wheel shake. I took my baby to have the tracking/camber wheel alignment done. Not as bad as I thought it was but both the front and rear camber is out, the rear adjustment is seized so they didn't do that and obviously there's no adjustment on the front. The rears were only just out but the fronts need doing (or so they said), so the question is do I get adjustable camber arms or change all the shocks?
specialty zed in the states do a front camber correction kit for $90.the top arm bolts are replaced with longer ones and you insert shims behind the inner wing bracket to correct the camber.
probaly just that the front springs have got slightly shorter over the years.a common 300 fault due to the weight of the engine etc.most zeds suffer from this but it doesnt mean you have to rush out and buy new shocks and springs which cost a packet.if the front shocks still rebound ok and arent leaking then why change them.you can correct the negative camber by adjustable top arms for £200 or a shim kit for about $90.the shipping wont be much as the items dont weigh much.$90 is about £50 by the way.as long as you can get the suspension geometry within spec then you wont have a problem.
