speedo x wheels
Hi does anyone know how far out the speedo will read with bigger wheels fitted, i have 18's. Thanks
carl
If it was accurate with standard wheels on , it should be with larger wheels becuase for every inch in diameter of the wheel you go up , the tyres should go down a profile , this will keep the rolling diameter of the complete wheel and tyre combination the same as a standard size.
Also unless you go for too wide a tyre you shouldn,t have any problems with tyres catching , as long as you,ve got the correct offset on the rim. HTH :D
