Base idle adjustment screw
Soory that probably sounds a bit silly. The reason is because I cannot get the base idle correct as the screw will not come out far enough. It's fo cleaning purposers really.
If you cant get the base idle down to around 650rpm's then you probably have a Vacum leak somewhere.
do a search for idle adjustment-theres more to than just turning the screw.
